Yes they do, but sellection is very limited.
Possibly only white spoke. And you will need to double check the hub center diameter. They used to be popular on Chevy trucks, so I don't know if the hub center was sized accordingly.
Also before you spend the cash, take some measurements, the 15" 8 lug were popular when front axles still used drum or small rotor front brakes. They may not fit on a "newer" 3/4 ton with a factory 16" or larger wheel.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
