It can be covered accept for when having a chassis certified, etc.
The material I`m using weighs nothing and is easy to work with cos I painted my bar last night w/rustoleum and a 2" fine brush but in 60 degree weather(even though the can said above 50 degrees was ok)it ran and looks like shight so either I sand and re-paint or cover it............
Since your SUB 10.0 you need SFIcerted pad where your helmet/head would hit the bars
I`ve never been asked about padding and I have none on the bar now so, can I cover it but if/when I cage it will I have to removed it or can I cut a patch out where they can test it and also put my cert. Thankxxx...........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
