Mopar now uses a stamped steel gasket that will not push out and leak. Pretty staight forward to change it. Be careful with the intake bolts next to the water passages in the heads thay are prone to corrode and sometimes twist off durring removal. Might wanna pick up some new bolts before you start.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
