Fuel only injected thru hat no port nozzles (class rules). This one thing that I will warn you of we had alot of trouble withthe front cyls running hot and the back dead cold.
you should have run different compression ratios in the different cylinders
BB, TT5,Procharged 3300lb Street Car 4.79/154
