Put both ammeter wires on the same ammeter stud to bypass the ammeter if you want to eliminate the ammeter (if I'm reading this right) & check/clean the ring terminals first. Neg voltmeter terminal/case to ground, Positive voltmeter terminal to switched 12V either fuse box or ign switch ign1 (run) wire
