It's doable. I got low 12's from a pump gas .030 over 360, stock J heads and a hyd cam. It had a stock bottom (had it balanced) 750 Holley, Strip Dominator, MSD ignition, 1 5/8 headers w/mufflers in a 3100# F-body. 999 T-Flite with a T/A manual valve body and a Dynamic 3500 converter. 9" slicks 26" tall through a 8 3/4, spool 4.56's S/S springs/snubber.
If You Can't Be Good, At Least Be Colorful
