Is this a Pittsburgh seam? Usually you can see a notch at each end of the seams male and female, line those up and start running the seam together. I'm a sheet metal worker for the union, spent some time in the fab shop, a duct 90* elbow is basically the same as a wheel tub.
Not sure what a Pittsburgh seam is. It looks like a double bend or S shape. The rad of the tub is just a 90* roll. It needs to fit into one end of the S then the end of the S to be tapped over to hold it in.
Cheers Don.
