Ya that looks tight under there for sure and although it looks like I might have just a bit more clearance than you I still want a taller filter than the 14x3 I run now.
1 thing i'm looking into is removing my fuel regulator plate from under the carb that will give me aleast a 1/8 in more room....Good luck on your goal
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
