Quote: I've read of more guys bolting them on then guys welding them on.
Also, what are you guys using to lube them? Just your run of the mill wheel grease, oil, or???
Like I said "I" havent seen anyone bolt them on... maybe if someone doesnt have a welder they would bolt them on.... the ones I have put on are welded... I use a spray white grease
