if they have cooling fins in the middle you want them to scoop the air...the slots usually go forward as they match the cooling fins. did they have a side denoted on the box?
No, no label of any sort.
The rotor does have internal cooling fins that the holes are drilled into, the slots do not go deep enough to reach the fins.
