I've had $1,000 custom fabricated intercoolers break and leak... and also had $200 eBay intercoolers last forever. There is never any guarantee - regardless of what you pay for things, so I wouldn't let the $$$ spent be a factor.
Where are you going to mount the heat exchanger/radiator for the intercooler system? Air/Water IS super efficient - but you have to be able to shed the heat that's introduced into the system.
Front of the car, using two Durango auxiliary heater coolant pump to circulate the fluid
Luke
