as i stated in the first post, everything came from tim banning at FHO. here are the specs of the engine:
- mopar mega block
- 4.5" bore 4.25" stroke
- CP pistons, 10.25 - 10.4 CR depending on the calculator
- .027" cometic head gasket
- 7.1" rods, don't know the brand, tim has them made up
- ohio crank
- cam specs listed earlier, comp cam, crower lifters, solid roller on more of a hydraulic grind
- stage V heads, intake flows ~435 at .800, completely worked over by tim
- i don't know the brand of the rocker gear, but came from tim
- stage V dual 4 intake
- dual 650 edelbrock thunders
- mopar electronic distributor and MSD
that's the basics off the top of my head.
i'm jazzed, can't wait to get it in the car!
