Finally got around to pulling the iac off. Cleaned it and the hole it sits in out with qtips, shop rag and carb cleaner. Also cleaned up the battery terminals. Truck fired up and kept running so I think we got it. Thanks again for all the suggestions!
You should have pulled the TB off the intake and cleand all of it. The edge of the throttle blades get a thin layer of carbon as well as the bores. This effects idle speeds and can cause some stalling also. I would suggest removing it as I stated above and do a complete job.
Outcast Dodge guy.
