Most likely you have 2 seperate problems? the dome lights and radio is probably a fuse,could be on the same circuit. The rear wiper should not. The wiper will be ignition power, while the dome light should be battery constant power and the radio needs a battery constant power also. most likely related. Are you sure the rear wiper went out at the same time?maybe just didn't notice it before?
