For my needs its plenty loud enough with good sound. I have Polk Audio speakers front and rear. It also has amp outputs so you can boost the output too. I will admit before I got rid of the flowmasters and their drone I did have to crank it!
Edit: I did have to file the corners of the face plate to round the edges to match the opening in the gauge bezel but it was not much.
Pics? I'd like to see one installed. Where did you put the USB/SD dongle?
