New to the site, am finishing up a restoration on our Cuda. Correct restored factory horns added, tested and work. Replaced horn relay, the kind that connect to fuse block. Wires look good from firewall to horns. Wire and horn ring look good and intact. Horn relay does not click when I push horn, no power to wires going to horns. Just not sure what problem could be, any help is appreciated.
