Unfortunately when it comes to batteires, to increase the capacity the physical size usually has to change. I have yet to see an AGM battery in that size with that kind of cold cranking amps. Cold cranking amps is a 0 degree rating, the hotter it gets the better the battery will perform. Hopefully the battery does what you need it to do.
