Can`t find the post about min size cable needed from starter to pass side trunk mounted battery. Now I run this heavy cobbled together welding cable and it needs to go so what`s the gauge I need pleeezzzeee.........
Stick with 1 gauge and you won't have any problems. Thats what I use ( bought a trunk mount kit ). I also ground to the frame rail just under the trunk mounted battery.
What he said!
Fastest 300
