If it is a V8 3-speed, all you would need is the 4-speed, shifter & linkage, as the bellhousing will be dual bolt pattern to accept either transmission. We can supply whatever you need.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
