Yes a stock 59* block with -1 heads. I'm running the 360-1 245 cnc heads on my magnum block with T&D 1.7 shaft rockers and comp offset lifters. I had to grind the block to fit them, well I didn't grind enough apparently and broke two link bars from wedging into the block.
Must not have been 8043's? 8043 lifters are not offset, and you cannot run offset lifters in a 59° block!
Deputy
Brian Hafliger
