Since we're talking about building headers, where can I get that star shaped filler piece that fills in the space between the primary pipes before the collector is put on? I don't know what that piece is called, so its hard to find it online.
The "merge collector"? or just the piece with the 4 holes in it that is filler?
I beleive he is asking about the filler where the 4 tubes come together and form a point in the collector.
http://www.coneeng.com/collector_components.html
For what its worth I just make the star.. stand 4
tubes on a piece of hard paper and trace them then
cut the metal using the template... I tend to buy
a slip on collector so I dont have to mess with the
filler star
To the OP... most times the package kits for a chevy
end up being the cheapest... you will have plenty
of bends and straight
