Quote: Never used one never had an issue. Seperate ignition and start buttons like most switch panels use will work wonders. Get the motor spinning before you hit the ignition and there will be no problem. Just my
+1. Cheap, easy, works!
yep---- i just mounted a toggle sw that kills the "run" circuit---works awesome--motor spins over easy
