Re: Plugging a Hole - SAE, NPT, WTH?
[Re: RapidRobert]
#1353056
12/17/12 05:26 PM
12/17/12 05:26 PM
Posts: 775 San Antonio, Tx
bulletpruf
San Antonio, Tx
You're talking about internaly plugging an aluminum male heater hose nipple? Yes you'd want to NPT tap it if you do & not sure if there's enough wall thickness to work with (there might be just never looked at it that way). Much easier would be to get a black neoprene end cap from the HELP section at your parts store along with some gasket cement and a hose clamp. You could paint it engine color to try & hide your handiwork. Functionally it'd be fine
OD is .880 and ID is .640, so I have .240 thick wall to work with.
I'm familiar with the hose clamp/rubber plug deal, but this is going on a road racer, and if I spill water on a track (and under my rear wheels), I might end up meeting Mr. Concrete Barrier. So, I want something more permanent. I may put an NPT plug + rubber plug and hose clamp, just to be safe.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Entire Thread
bulletpruf
12/17/12 07:26 PM
Dean_Kuzluzski
12/17/12 07:32 PM
feets
12/17/12 08:09 PM
bulletpruf
12/17/12 08:45 PM
JohnRR
12/17/12 08:46 PM
bulletpruf
12/17/12 09:21 PM
JohnRR
12/17/12 10:54 PM
bulletpruf
12/17/12 11:21 PM
JohnRR
12/17/12 11:26 PM
bulletpruf
12/18/12 03:32 AM
ahy
12/18/12 03:55 AM
Cab_Burge
12/18/12 07:48 AM
runinonmt
12/18/12 04:00 PM
bulletpruf
12/22/12 09:50 PM
6PakBee
12/23/12 03:33 PM
RapidRobert
12/17/12 08:47 PM
bulletpruf
12/17/12 09:26 PM
VincentVega
12/17/12 09:29 PM
bulletpruf
12/17/12 10:00 PM
