I was racing both box and no box... I used a Biondo
adjustable button... either set it up so the button
is right for no box and the bottom bulb and adjust the
delay box to leave the button as is OR set the button
back to zero on the box(I left the button alone and
set the box to accommodate the button)... I could have
my box out in about 30 seconds.. unplug the box and
plug in a jumper then I had 2 switches I had to flip
to change the ground
