How fast have you guys gone with 7260 u-joint pinion yoke with straps???
I still have the 7260... been 8.90s so far but in
a light car.. if you have a heavy car it could break
if it has good traction.... just like the 8 3/4 if
the car is light you wont have any problems... and yes
I still use the straps... if you look at the design
of the joint you will see that it slips into the yoke
OVER half the diameter so the load is applied to the
yoke and not the straps... the strap just keeps it
from sliding forward
