Re: Mini-Starter, Rear Cam Plug, Questions ??
[Re: 69CHARGERMD]
#1350970
12/13/12 10:57 PM
12/13/12 10:57 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
After tearing up the car last fall, I am gathering some parts. Ordering a new flex plate, ARP bolts, etc.
I tore up my starter as well,,,,
Was looking at Mancini's site, they have them ranging from $130-240 ? ( mancini brand/denso/powermaster/etc)
any real difference here ? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
thanks Doug (ps, Trans is going back to CRT for a freshin up, Convertor back to Turbo Action for some minor repair)
Should be up and running by spring.
PSS,,,I also need a rear CAM PLUG for the back of the block.. where can i get one of these without buying a entire kit for the motor, just need the one plug,,thanks *************************************
My STAY AWAY from the Powerbasterd starters!!
If you like drag racing, support your local track.
Entire Thread
69CHARGERMD
12/13/12 09:22 PM
Re: Mini-Starter, which do you run ?
rt66jim
12/13/12 09:26 PM
bobs66440
12/13/12 11:31 PM
Cab_Burge
12/13/12 11:30 PM
CHAPPER
12/14/12 02:57 AM
fourgearsavoy
12/14/12 03:41 AM
