Where are the rules posted for this race? I know that there are power adders allowed, so that answers one of my questions. If the rules look enticing, I would be willing to drag my new small block car to Indy, to hurt some big block feelings.
Open to Mopar powered, Mopar door cars only 1/8 Mile, Heads Up, .400 Pro Tree, 16 car field Rear Tires 29.5 non w or 315 radial (29.5" tall tires allowed up to 10.5 for a slick and 13.5 in a dot street tire) Must retain stock fire wall and front frame rails in stock location, aftermarket bolt on front suspension allowed Any rear suspension allowed Wheelie bars allowed Backhalf (aftermarket rear frame rails) allowed Stock appearing interior (stock style dash, can be fiberglass) Any power adder allowed Weights: Boosted big block 3300lbs Boosted small block 3100lbs Nitrous big block 3100 Nitrous small block 2900 N/A big block 2800lb N/A small block 2600lbs (Deduct 50lbs for Leaf Springs) (Deduct 100lbs for the following cylinder heads: Indy 440-1, Indy EZ, Indy SR, Bulldog, Edelbrock, 440 Source, Mopar Performance, Pro Comp) (Deduct 50 lbs for Stock Factory Iron Block)
BB, TT5,Procharged 3300lb Street Car 4.79/154
