Give it a vac leak after you get a base sniff and
do it again.... what is your A/F at mid range
You could also add a gallon of denatured alcohol to your fuel tank...it helps with smog issues/ runs cleaner..
I thaught about a 91 pump gas test compared to the VP-100 I generally run but not sure about your deal..............something to think about.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
