Here's an original paint Q - "electric blue metallic" in Plymouth speak - trunk compartment. Notice the change in color as coverage lessens into the nooks & crannies.
Q is bright & vibrant - U not so much.
I bet the teal you are seeing is "oil" leaching from the undercoating? Use some cleaner wax on the windshield jamb or rear wheel tubs where paint is the thickest & it should clear it up in person - the color choices are not that close.
