Quote: Here's the Flasher. Same for Charger and Fury.
What is the flash rate for this flasher? It does not appear to be commonly available. It appears to be a two prong flasher and I would expect it is 12 volts and flashes only 1-2 times per second. From what I could tell from searching online, they were made by Tungsol in Newark, NJ or Ideal corporation of Brooklyn, NY. Also, the reservoir for the Fury appears to be different than the one for the Charger.
