I did alot of work with this intake and there is an early version and a later version, The later had interchangable tops and the base is the better starting point. For under 500 cu.in. around 3/4" between plenium and top works well. Over 500" this intake is not a good performance choice. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
