Who has the combination 7260/7290 U Joints for sale. The Spicer U Joint I have will not fit into the pinion yoke side when installing the drive shaft. It is a 7290 U Joint. Fits fine to the drive shaft but not the Yoke. I do not have the time nor want to replace the Pinion Yoke with the larger 7290 set up. Thanks
