DO NOT MILL 6.1 HEADS.
You only need to run something about a 219/223. That has taken LX's into the low 11's with heads
The 6.1 doesn't need the higher compression. You can't run bigger than about 223/227 without running into serious piston to valve clearance issues.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
