Getting ready to send my block to be machined and would like to get some input on pistons to use. I want to run pump gas and I'm using factory heads that came off my 85 engine. I would like to get an honest 9 or 9.25 compression ratio. The block will go .030 over and have the decks squared up. I looked at KB-107's, but I think they may put me a little higher than I really want to go. Speed Pro H116CP's look like they may be a little less compression, but still get me in the ballpark.
Just need some input from people that have done this. I appreciate any suggestions.
