.030 over 383, TRW L2315's, block milled for .020" positive deck height, stock rods w-ARP bolts.
stock 906's flowed 235, Comp solid cam, 256/262-106, .565/.580 lift, 1.5 Isky rockers, RPM intake, ported 850 Holley, Hooker Comp headers.
dynoed at 485hp.
went 11.30's/40's in "normal" air, with a flat hood, mechanical fuel pump, full interior, heater, wipers, etc......3670lbs race weight.
on hot summer days, 11.50's.
6 pak hood, electric fuel pump, 100lbs lighter.....went 11.18 @ 123, 1.51 60 foot.
the key is getting the car to work.
lots of gear, lots of stall, good hook.
i ran 30 X 9 radial slicks, 4.56 gears, 5400 stall 8" Dynamic converter.
