What size carb. and needles and seats? As already said, fuel pressure and fuel delivery are not the same
825 Demon. Float levels are OK. .110 needle and seats. I cant see it being a needle and seat restriction issue, motor only makes maybe 425HP. Pressure is fine, at least at idle. 7 PSI at idle.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
