Re: 727 filter extension for deep pan
[Re: JohnRR]
#132928
10/06/08 04:02 PM
10/06/08 04:02 PM
Is that mancini piece the same thickness as your B+M piece ?
I have a couple from A+A , it looks like the one in the pic except it has a couple of hogged out areas to reduce weight , made it a pain to trim as I had to take material off both sides and then put the oring groove back .
you could just modifiy the one you have to make it sit flat and get a gasket
im not sure how thick it is but the picture makes it look about the same. I'll find out when it gets here I guess. how thick are yours (I can check mine when I gtet home tonight)?
I was thinking that all I really needed was a gasket that closed the 2nd hole in the adapter but I figured I just buy the right piece and be done with it (I hope this one is the right piece). for all I know, Id use the wrong gasket material which would disintergrate and clog the VB or leak.
