yikes - i think you'll find this kit has everything you need - Holley 3-396 Carburetor Renew Kit - and they're about $20. is there something in mechanical six pack setup that's THAT different?
Tech says his records show that the Holley mechanical carbs had a different renew kit part number, but they supercede to the same 37-1537 number. He doesn't know what was different about the kits, but figures that the 37-396 may work.
Now I think about it, the factory Six Pack cars had center inlet fuel bowls; the Muscle Hustle carbs have side inlet with the inlet on the driver's side. Bowl gaskets are the same, aren't they? Different needle and seat? If there are differences, should be no problem getting individual parts needed. Better than paying $90 for the big kit.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
