Well what I've been hearing is the E-85 has been especially troublesome with the gaskets sticking to the components. Also some issues with gasket swell and delamination.
This has been from many popular brands of gaskets.
I'd like to find someone who runs E-85 to test a set of what I have. Testing so far they work real well with pump gas and race fuel. So good in fact when the bowl is removed the metering block usually falls off to
Jeff do you run Ethanol? Are you doing any more racing this year?
These are made from the same material as the base gaskets
I know what you all mean with them sticking as I've had to beat the bowls & blocks of many times myself
I appreciate all the responses
