i think bolt a fuel pump on and good to go.
that is INDEED the fuel pump ecentric.
if the arm on the FP wants to hold you up on the bolt aline ment,rotate the engine and roll the ecentric to the far side and pressure of the pump stroke.
Sweet!!!!!! So I am assuming that the eccentric is lobed? How else would it move the pump arm?
