I am looking for the name of the grease that is very silky and smooth, grey in color. It is inside my power window motors where the gear is, and a small packet is supplied with new plastic gear, but not labeled. I would like to clean out the tracks on all four and re-lube with this stuff as I believe it is better than bearing grease, which I have used before. I guess the bearing grease requires some heat to work best, and in the winter really hardens up. Anyone know what the grease I am describing is called? Thanks.
Facts are stubborn things.
