They dont usually bend valves.The valves actually hit each other depending on the RPMs.My wifes broke at about 25 MPH.New belt and WP and runs fine.They are a pain to change as its really tight in there.The exhaust cam has to be about 1 tooth off the timing marks when you set the cams.Rocky
Chrysler Firepower
