What size squirter did you go to
it had a 25 we went to a 28 then 31 then 35 didn't change it always has to be pumped once before it shoots as if it's bleeding the fuel back and need's to be pumped back up to the squirter, I think it a bad seat in the main body thats allowing gas to bleed back and leaving a air pocket at the squirter.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
