Which trans ? A body 4 speed is the same length as a 904 , if you go to a 727 you need a shorter driveshaft.
either trans...thank you for point out those differences...are there any other 904/727 differences at all?
904 is lighter and has smaller internal parts , you'll need to spend $$$ to build either for nitrous, more on the 904.
Thanks for the info. Is there anything else that I am missing about the swap???
