what seems to be wrong with the box you have?
what part of Fl you in? dade or dade city?
on my 68 dart it would keep leaking oil,so i filled it with wheel bearing greese.
are you serious!!! did that work? doesn't it squeal cause the grease is too thick. you're joking aren't you
talking manual steer not power steering boxes.
it worked for my alum manual steer box for yrs,every so oftern I would pull the fill plug and add a little,it would slowly poop it out the top seal/shaft.
i would also add a little gear oil to wash the greese around and thin it some,then go back to add just greese to thicking it up some so it did not poop all the time.
