You may have found your problem. Probably a lifter or two out of its bore.
For the others who have experienced something similar, consider the pressure relief valve in the oil pump. If you are running at highway speeds your pressure relief valve might be open and if it sticks open, the next time you start you won't have much oil pressure.
R.
