I have a Sixpack 69 1/2 and the friend of mine got a 70, thats why both are interesting for us. The most important point is: how do they come on a C/R 10.5:1...
69 1/2 is rated 10.2:1,70 is rated 10.5:1.Different pistons with valve reliefs.
where is this information from, do you have pistonpics?
70 the piston is a flat top and has 4 valves reliefs , it should be about .020 below the deck
69 is a flat top NO VALVE reliefs and will be about .040 below the deck
