I assume you mean to cut the overall profile with a lower base circle. Same lift duration, etc. Is it expensive to have a cam recut?
Will the ramp profiles work the same?
They can cut your cam as is on a smaller base... it
just drops the lifter lower... how much d you need
to drop.... its about $125... I just called on this
last week
