The truck has a 3" suspension lift to go along with 3" body. The bump stops are a good ways from the leaf springs so there are no signs of them hitting. The truck rides good and doesn't "bottom out" on the front suspension. I assumed the front springs were straight when new and didn't know if the negative arch was from age and wear or if that is normal and not an issue...?
Are you saying it has a lift because of the block in the rear? If so its Stock. 4wds sit higher than 2wds and the block in the rear is stock. A negative arch in front wouldn't be a lift as they are arched to much and I've never heard of them sagging that bad
