Moparforlife nailed it. You said you measured 3.906". That's .004" smaller than the minimum. That right there should tell you it's not accurate. The biggest problem is probably the caliper. I have 3 and none read the same. Their all within 2-3 thousandths which is ok for most things but not all.
68 Cuda 408/904/8-3/4
02 Dakota 4.7 auto
